Skip to content
How to install the VCV Rack plugin manually
There is normally no reason to install plugins manually. However, if you were asked by Support to try a special version, or are beta-testing, then here is the procedure to do a manual installation:
  • 1. Download the plugin
    From the Downloads page, click to download the plugin for the type of computer you have. If you have a Mac, make sure to download the x64 version for an Intel processor, or the arm64 version for a newer Apple silicon processor.
  • 2. Find your VCV Rack User Folder
    From the VCV Rack program, select "Open user folder" from the Help menu.
    A folder called "Rack2" will open on your screen.
    Alternatively, you can open the folder manually:
    • MacOS: ~/Library/Application Support/Rack2/
    • Windows: C:\Users\\AppData\Local\Rack2\
    • Linux: ~/.local/share/Rack2/
Open user folder
  • 3. Put the downloaded file into the plugin directory
    The folder is named after the type of computer and OS you have, but always starts with plugins-
    For example, on a Mac with Apple silicon, it's called plugins-mac-arm64, and on an Intel Mac it's plugins-mac-x64.
Copying to plugin dir
  • 4. Quit and re-launch VCV Rack
    Right-click (or control-click) on any empty rack space to open the Add Module page and see the 4ms modules.
4ms Modules in VCV
