Using the MetaModule: MIDI jack mappings
The MetaModule can host a MIDI controller, or can connect to computer as a USB MIDI device. Everything on this page works the same either way. See USB Device Mode for more information about USB modes.
MIDI Maps to parameters
You can map MIDI CC or Note Gate on/off to parameters such as knobs, switches, and buttons.
See Using MetaModule for a detailed description of one method for adding MIDI maps.
Quick MIDI Map Shortcut
You can quickly create MIDI CC or Note on/off mappings with MIDI Assign mode.
3. Press and hold the rotary while sending a MIDI CC or Note
Release the rotary when you see the MIDI event appear.
The parameter will be instantly mapped.
You can remove the mapping by holding down the rotary and tapping the Back button.
Turn off MIDI Assign mode when you're done, or it will automatically turn off when you open a different patch.
See more shortcuts on the Shortcuts page.
How MIDI parameter mappings work
You can map MIDI CC or MIDI Note Gates to parameters such as knobs, buttons, switches, etc.
The parameter value is always updated immediately when a MIDI message is received, regardless of the current Knob Catchup mode in the preferences page.
On the Edit Mapping page, each MIDI mapping can be set to respond to all MIDI channels, or just a particular MIDI channel.
The MIN and MAX sliders determine the range of the mapping in the same way that they do for panel knob mappings. For MIDI CC mappings, this means a CC value of 0 will set the parameter to the value set by the MIN slider, and a CC value of 127 sets it to the MAX slider's value. For MIDI Note Gate mappings, the note can only be on or off, so the parameter will be set to the MIN or MAX slider value.
Additionally, both kinds of MIDI mappings can be set to Toggle or Step mode, which makes the parameter change value each time a note is played or a CC goes high. See Button Behavior.
Note that while you can only map MIDI CC and Note Gates to parameters, you can map any MIDI message to input jacks: see MIDI Input Jacks.
Editing the MIDI Channel of a MIDI Mapping
From the Module View page:
3. Adjust the MIDI Channel
You may adjust the MIN/MAX sliders and the mapping name in the same way that you do for normal knob mappings.
You may also change the Button Behavior (see below).
Button Behavior: Normal, Toggle, and Step
Every MIDI Note Gate mapping and MIDI CC mapping has a Button Behavior setting on its Edit Mapping page, with three choices:
Normal
The parameter follows the MIDI message.
MIDI Note Gate: when a Note On message for that note is received, the param's value will be set to the value of the MAX slider. When a Note Off message is received, the param will be set to the MIN slider's value.
MIDI CC mapping: the parameter smoothly follows the CC value, from the MIN slider's value at 0 to the MAX slider's value at 127.
Toggle
The parameter toggles between MIN and MAX.
MIDI Note Gate: Each time a matching Note On message is received, the parameter will toggle. Note Off messages are ignored.
MIDI CC: Each time the CC goes from the low half (0-63) to the high half (64-127), the parameter will toggle. Going back to the low half does nothing.
Technical note: In case the param has changed value since the last MIDI message, the MetaModule will set the value to MIN or MAX based on which one the current value is farther from.
Step
A multi-position parameter steps through its values, going back to the first one after it passes the last one. This is meant for parameters with more than two positions, such as a three-way switch. The number of positions is shown in the menu, for example
Step (3).MIDI Note Gate: The parameter steps to the next position each time a matching Note On message is received. Note Off messages are ignored.
MIDI CC: The parameter steps to the next position each time the CC value goes from the low half (0-63) to the high half (64-127). Going back to the low half does nothing.
The MIN and MAX sliders limit which positions are stepped through. If MAX is less than MIN, the positions are stepped through in the opposite direction.
When you map a MIDI Note Gate or MIDI CC to a parameter that has more than two positions, the new mapping defaults to Step mode.
Button mappings on the MetaButtons expander have the same three choices.
MIDI Input Jacks
You can patch MIDI signals to input jacks in two ways: using MIDI mappings (aka "Built-in MIDI"), or by using RackCore modules such as MIDI-CV, MIDI-Gate, MIDICC-CV.
Patching MIDI Input to jacks
1. Click on an input jack, and click New MIDI Map
If the jack is already connected to a panel jack, then this button will not be displayed.
2. Select a MIDI signal
Choose from:
Note events (keyboard): select Pitch (key number), Gate (note on/off), Velocity, Aftertouch, or Retrigger (multiple note-on). Also select the polyphony channel (see MIDI Polyphony):
- #1-4: a single polyphonic cable carrying voices 1–4.
- #5-8: a second polyphonic cable carrying voices 5–8 (use this in addition to a #1-4 cable to reach 8 voices).
- #1 … #8: a single mono cable for one specific voice.
CC: Continuous CV scaled to 0V to 10V. Select a CC number, or send a CC event to "learn" it.
Pitch Wheel
Gate on Note: fires a gate whenever a particular note is pressed. Select a note or play a note live to "learn" it.
Clock: Select the raw MIDI clock (24PPQN) or a divided version of that.
Transport: Sends a gate for Start, Stop, and Continue events.
Channel: Select "All Channels" or a choose a particular MIDI channel to respond to.
Using the MIDI to CV module
Using the MIDI to Gate module
The MIDI to Gate module converts incoming MIDI notes into gate/trigger outputs (16 jacks). Each cell can be assigned to a note, and can output a held gate or a trigger.
2. Optionally choose custom notes for each jack
Select
Options>>at the bottom and then choose custom notes for each "cell" (jack).
Using the MIDI CC to CV module
The MIDI CC to CV module converts incoming MIDI CC messages into CV (16 outputs), each assignable to a CC number.
Select
Patching Outputs to MIDI
To support MIDI Output, the MetaModule has the CV to MIDI and
CV to MIDI CC modules in the RackCore brand.
Third-party plugin modules that produce MIDI Output should work, as well.
Note that the MetaModule always acts as a MIDI Host, and never as a MIDI Device.
CV to MIDI (Notes)
2. Patch the CV and gate signals you wish to output as MIDI
A log of MIDI events will appear on the module's screen.
CV to MIDI CC
The CV to MIDI CC module converts CV inputs to MIDI CC messages. It has 16 CV input jacks arranged in a 4×4 grid, each independently assignable to any MIDI CC number. Use CV to MIDI CC when you want to drive external MIDI hardware or software synthesizers with CV signals from your patch.
- To use, patch CV signals into any of the 16 jacks. By default, Jack 1 → CC 1, Jack 2 → CC 2, and so on.
To assign a CC number to a cell:
Click
Options>>>at the bottom of the list, select the cell, and choose a CC number from the list.Two cells cannot have the same CC number assigned to them.
Gate to MIDI
The Gate to MIDI module converts gate/trigger inputs into MIDI note on/off messages, with optional velocity from the input level.
- To use, patch gate signals into any of the 16 jacks. By default, Jack 1 → C3, Jack 2 → C#3, and so on.
To assign a note to a cell:
Click
Options>>>at the bottom of the list, select the cell, and choose a note from the list.Two cells cannot have the same note assigned to them.
Viewing all MIDI mappings
You can see all built-in MIDI mappings on one page.
1. Click the MIDI button on the Knob Sets page
The Knob Sets page is opened by clicking the Knob icon at the top of the patch.
If there are no MIDI mappings, this button will not be visible.
2. All MIDI mappings are shown
The left side shows all MIDI jack mappings (maps to input jacks).
The right side shows all MIDI parameter mappings (maps to knobs, switches, buttons, etc).
Manually created mappings using the RackCore modules are not displayed here, but can be seen as normal cables in the patch view.
MIDI Polyphony
The MetaModule has built-in MIDI polyphony. MIDI note information (pitch, gate, velocity, aftertouch, retrigger) can be carried on polyphonic cables, with up to 4 voices per cable. By using two poly cables — one for voices #1-4 and a second for voices #5-8 — you can play up to 8 voices of polyphony.
When you create a MIDI note mapping from within the MetaModule, the polyphony
dropdown lets you choose a #1-4 poly cable, a #5-8 poly cable, or a single
mono voice (#1–#8). See Patching MIDI Input to
jacks.
Setting the polyphony number
The number of active MIDI voices is shown and set in the Patch Info dialog, under MIDI Poly Chans:
Auto (the default): the MetaModule automatically detects how many voices the patch needs by scanning its MIDI mappings. If any
#5-8poly cable is used, 8 voices are allocated; if only a#1-4poly cable is used, 4 voices; otherwise it uses the highest mono voice number that's mapped. -
1 – 8: force a fixed number of voices, regardless of what's mapped.
The dialog also shows Active poly chans, the number of voices currently in use.
Note
When more notes are played than there are available voices, the MetaModule reassigns voices to the new notes (voice "stealing").
MIDI Feedback
MIDI Feedback, also known as "bi-directional MIDI", is a feature that allows a MIDI controller to stay in sync with the MetaModule. When this is enabled, the MetaModule will send MIDI CC, pitch wheel, and Note on/off messages back to the controller whenever a parameter changes value. When a patch is loaded, the MetaModule will send the value of all MIDI-mapped parameters. If the MIDI controller supports MIDI Feedback, then it will update its display or internal state with the new value.
For example, if you map a CC to the Pitch knob of your VCO, then when you load that patch, a feedback-aware MIDI controller will jump to the current value of the pitch, perhaps by displaying this value on a screen or even by turning a motorized knob like the Roto-Control does.
As you play the patch, if you adjust the VCO's pitch knob manually (using the Adjust button) or by mapping a panel knob to the Pitch knob, then the MIDI controller will stay in sync with these new parameter values. Also, say the module happens to have advanced features such as scale quantization, such that when you select a scale the Pitch knob jumps to the closest note. The MetaModule will still keep the MIDI controller in sync even if the Pitch knob changed indirectly (e.g. because you selected a new quantization scale or a new preset).
If you need to re-send all MIDI-mapped values to the controller, for example if you reset the controller after loading the patch, simply pause and unpause the patch playback. This will send the current value of all MIDI-mapped parameters.
To enable or disable MIDI Feedback, check the box in Settings > Prefs > MIDI:
By default, MIDI Feedback is enabled.
14-Bit CC
Normally, CC messages are 7-bit, ranging from 0-127. When controlling certain parameters this can cause "stepping" or "zippering" since the difference between each CC value is relatively large. For example, if patched to a 1V/oct CV jack, each CC value would be about 78mV, which is almost a semitone.
To increase the resolution, some MIDI controllers can send 14-bit CC signals by combining two CC values. With 14 bits, the same CV jack would see steps of 0.61mV, which is less than 1 cent when patched into a 1V/oct jack.
The standard approach is to use a CC number from 0-31 for the upper bits and a CC number that's 32 higher for the lower bits. For example, CC 2 would contain the upper 7 bits and CC 34 would contain the lower 7 bits. MIDI controllers that support 14-bit CC messages will automatically handle splitting the bits and sending out both CC messages whenever the parameter is updated.
When the 14-bit CC feature is enabled on the MetaModule, mappings to CC numbers 0-31 will be high resolution. CC 32-63 messages will be ignored unless also accompanied by a corresponding CC message that's 32 numbers lower.
MIDI CC Knob Set switching
You can use a single MIDI CC message to instantly switch between the eight Knob Sets in the current patch. This is useful for changing performance "scenes" using any MIDI device that can send CC values.
When enabled, sending a CC value of 0–7 on the chosen MIDI Channel and CC# will immediately make the corresponding Knob Set active:
| CC value | Knob Set |
| 0 | Knob Set 1 |
| 1 | Knob Set 2 |
| 2 | Knob Set 3 |
| 7 | Knob Set 8 |
CC values outside the 0–7 range are ignored. The CC# you choose for Knob Set switching can still be used as a normal MIDI parameter mapping.
To enable this feature, go to Settings > Prefs > MIDI and set the MIDI Channel and CC# for Knob Set switching. See Preferences.
For more information about Knob Sets, see Knob Sets.
Loading patches with MIDI Program Change
You can load patches by sending MIDI Program Change (PC) messages. This lets you recall patches hands-free from a MIDI controller, sequencer, or DAW — useful for switching patches during a live performance.
Each patch is assigned to a Program Change number (0–127) on a MIDI channel of your choosing. When the MetaModule receives a matching PC message, it loads that patch.
1. Assign a patch to a PC number
Open the patch you want to assign, click the file/disk icon to open the Patch File Menu, and select Load on MIDI PC.
In the dialog that appears, choose a PC # (0–127) and a MIDI Channel. Set the channel to a specific channel (1–16), or to Any to respond on all channels. The dropdown shows which patch (if any) is already assigned to each PC number, so you can avoid collisions.
2. Enable MIDI PC Patch Load in the preferences
Go to Settings > Prefs ** and check "Enable" under MIDI PC PATCH LOAD**. This globally enables or disables the MIDI PC Patch Load feature. See Preferences.
Each patch can be assigned to one PC number. Assigning a patch to a PC number that is already in use will move the assignment to the new patch. To change a patch's assignment, open it and select Load on MIDI PC again.
